Ugh, S13 SR20 Auto -> Manual
BuudWeizErr
I know it's been asked before, and yes I searched, info was a little lacking.
Anyway, this kid I know wants to go SR20 on his auto 240. Hes going to get a front clip; does the FC come with everything needed to do the conversion? Does he need to grab a clutch pedal or can he use the one from the clip? What about the interior, transmission mount, driveshaft, clutch cylinders, etc, etc.
Bleh, why are autos so much easier to find?
chrispy
Car: 1990 Nissan 240SX HB
i am not sure if he can use anything. all the cables/lines would be for the wrong side. And i have no idea but the pedals might good.
BuudWeizErr
Anybody else? Not exactly the response I was looking for.
89sxRCR
Car: destroying self esteem
89 to the rescue for my friend budd. Yes the front clip will have everything he needs. He will have to do a little right to left conversion (for the master cylinder) but thats about it. It should come with pedals too, just ask whoever your buying it from. My clip came with the driveshaft also, but you should check that as well. just make sure everything is in good condition. :)
IvanS13
Car: *** & Titties
Couldn't you just convert to RHD? Might be a dumb question... 'prolly is.
Daunttless
If you want to convert to RHD, you would have to strip everything, cut out the USDM firewall and weld in the JDM one, its not real fun and unless you can do all the work yourself it costs a ****load of money.
johnpoppy
Have you checked the 240sx.org install site? It has some info, but you probaly already have seen this. ?
red240ne
Car: mmm...donuts
the installs section talks about auto -> manual for a s14 ka24de
Daunttless
The process is the same...
IvanS13
Car: *** & Titties
Doh... scratch the RHD idea :(
Garage Battle
Car: 180sx
Garage Battle
Car: 180sx
