Exia wrote:ty evil, I will call him and see if its there, the car has already been pick through, only reason I got the motor was the last guy wouldnt return the sellers calls. But do you guys still think I spent to much on that motor? and I still plan on fixing this issue before I convert it cause like you said I could do all of this and still have same issue, and it will be professionally done so yea you guys can breathe.
If you got all that other stuff with it, no. The price is pretty good. But I wouldn't use that engine at all if it's already bad. Just bolt on all the turbo goodies to your existing block.
Have you figured out the starter issue yet? When you do that, do a compression test on your current motor.
