ugh here we go again with the problems
BIGTIMER_240
Car: 1989 240SX ka24de
Okay guys i got this problem with my car it just started doing. it started doing this ticking noise like around 2,500-3,000 rpms when i take the second spark plug cable and i rev it its gone if i put it back the noise is back. what you guys think i think it might be a bearing that's going bad.
nightsauce
Car: 1991 Nissan 240SX S13 hatch RIP
1992 Nissan 240S S13 hatch :D
240s= problems...just today, my brakes decided to cut out. I'm on the fence about selling it.
BIGTIMER_240
yup me too and its my daily too, i hate asking for rides
BIGTIMER_240
any help guys
locoluna825
Car: 90 240sx coupe
pullign the spark plug wire wouldn't keep the internals form moving so i don't see why it would not be making noise while its unplugged if you pull the spark plug physically out does it not make the noise?
Modified by locoluna825 at 12:24 AM 9/23/2009
Modified by locoluna825 at 12:25 AM 9/23/2009
Klits562
Car: white s13 coupe
well if theres no plug the cylinder wont fire but idk what would be causing a noises in the cylinder
super240sx7185
Sounds like rod knock. When you pull the plug wire it keeps the cylinder from firing therefore taking pressure off the piston and rod so the noise quits.
locoluna825
Car: 90 240sx coupe
^^that is possible but he called it a "squeak" that's why im not sure what to think
BIGTIMER_240
dam it is going to be the rod knock, i am going to have to do it the ghetto way just replace the bearings what you guys recommend i just got fired and with little bit of money.
also it only does it like 5 minuts after its on. if i rev it while i barely turn it on it wont make the noise
Modified by BIGTIMER_240 at 4:08 PM 9/23/2009
Modified by BIGTIMER_240 at 6:26 PM 9/23/2009
super240sx7185
Thats because you spun the bearing and its barely out of round but if you don't stop running it, it will get worse. Then the rod will break.
locoluna825
Car: 90 240sx coupe
you should probably stop driving it till you can fix it. if you keep driving that thing your gonna end up making it worse and paying more to fix it
BIGTIMER_240
im not driving it no more its just sitting in the garage. my question is could i just replace all the bearings or wat should i do
1996N1ss@n240SX
Car: 1996 Nissan 240SX, 2001 Honda Accord Fully Stacked
BIGTIMER_240 wrote:im not driving it no more its just sitting in the garage. my question is could i just replace all the bearings or wat should i do
its a valve knock....hate to say it...but after those rpms my knock went away also...and before it it wasnt there...start you car up and see if it does it...mine did sometimes and didnt...if there is a squeel when u rev it like mine then goodluck.........like i said i HAD a valve knock then the engine blew up...so DONT drive it
BIGTIMER_240
