goalguy02 »
https://forums.nicoclub.com/goalguy02-u84875.html
Sat Jul 05, 2008 3:06 am
I have the same fun time doing this so I will give you my $.02.
I use a stubby wrench on #1. I have tried 1/4" drive, universals, ratcheting wrenches, etc and the only thing I have found to work fairly well is a small open end wrench. I found mine in a cheap tool set at walmart I think.
As for nut #2, I usually start the bottom three nuts all at the same time starting with #2. YOu have to put the elbow on just enough so the stud comes thru and you can start the nut on it. In my case, I have to thread it on a little, then start nut#1 a bit then #2,#1,#2 and so on. Eventually the elbow will sit flush to the turbo and you can start the rest. I would also use lockwashers and high temp loctite.
Hope it helps.
