Uggh: Offset question...15" Kosei K1 on S13
VA240
Gotta luv offset questions....Anyways....
The car is a S13 coupe with Suspension Techniques lowering springs used for daily driving. Looking at a set of Kosei K1 wheels 15 x 7 with 205/55R15 ES100 tires or 205/50R15 Azeni Sport tires.
I'm trying to decide on offset. Should I go with +17 or +27? Will I have to roll and/or pull the fenders with either of these offsets?
Thanks for the help,-VA240
Grant@tirerack
Car: Auto racing (AMLS, Cart,F1,IRL in that order), old show rods, classic monster and bad sci-fi movies,
The standard offset would be 38mm for that fitment. A 27mm would be the better of the two options as far as clearance.
VA240
Grant, thanks for the reply. Anyone else with some input?
Thanks,-VA240
Edit: For reference the front wheels on this car are supposedly 15 x 7 +27 offset with a 205/55/15 tire.
aither
Car: Rock Climbing
I'm pretty sure there is at least 20mm of spacer up front.
240marcuSX
Car: E34 525i
E46 M3
hey va240, where are you located? (if i havent asked you that before) im in petersburg. we should meet up.
VA240
aither wrote:I'm pretty sure there is at least 20mm of spacer up front.
That pic came from the following thread:
http://www.zilvia.net/f/showpo...nt=15
In that pic I don't think he's using a spacer, but there is another pic where I think he is using a spacer.
-VA240
VA240
240marcuSX wrote:hey va240, where are you located? (if i havent asked you that before) im in petersburg. we should meet up.
I'm in Richmond. We could try and meet up at Performace Autosport on Sat. nights:
http://www.dragva.com/forums/s...68975
Though I won't be there tonight.-VA240
