UEGO users I need your help!
DriftingisLame
Car: '91 240sx coupe, rb20det
I just bought a brand new UEGO gauge and wideband sensor from my friend - Thanks Carl!
However, it did not come with instructions. All I need to know is where I need to run each wire
Red - I'd assume is power when the key is on?Blue - ?White - ?Black - I'd assume is ground
Thanks a lot guys!-Max
DriftingisLame
Still need help
Veriest1
Car: '96 BMW M3
'93 Nissan 240SX coupe dd
It must not have been new in box because they come with a book of an instruction manual... unfortunately I can't find mine.
Have you tried AEM's homepage?
The red wire (power) from the UEGO goes to the power wire on the O2 sensor harness (identify with multimeter). The orange wire (signal) from the UEGO controller is spliced into the power wire on the O2 sensor harness.
The remaining wires on the O2 harness and the UEGO harness (white, green, brown and blue) are not used.
Red - powerOrange - signalBlack - Ground
daconkiftador
Car: '92 Coupe SE, '83 Rabbit GTi, '91 Golf GTi
azhitman saves the day, once again!
hypertek_sideview
Car: workouts, the beach
you are using a UEGO gauge on your stock narrowband o2 sensor??? I thought those kits came with a wideband o2
