ud pulley concerns
2005g35
Car: 2005 g35 sedan
just a quick question, I bought a 2005 g35 sedan as a daily driver and want to add some minor bolt ons.
question:
on the g35 is the crank pulley the harmonic balancer as well? and also are you concern about vibration at high rpms with a lighter UD crank pulley?
thanks,
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
Yes, the stock crank pulley is also a harmonic balancer.
I haven't heard anybody have any issues with using underdrive or just lightened crank pulleys or the whole pulley set.
I'm running a UR lightweight crank pulley.
If i was running FI then I would probably not do anything with the pulley because those vibrations could cause much more of an issue under that kind of pressure.
