S14Zilvia wrote:For those of you who have installed crank pulleys (ASP or UR), did you notice a big difference? I guess what I mean is would you spend the money on it again? For 120 bucks it seems like even for a little gain it would be worth it.
Right now I have exhaust, next is intake for sure, but after that is a ?. I'm thinking the pulley, cams, and/or headers... but I'm not sure which is the best step after the I/E.
S14Zilvia wrote:Well, I spent 460 on my Hiper and I think it was well worth it. After taking out the stock exhaust and just looking at it, I can't believe the car even runs with that crappy system.
Intake is next, and I guess the pulley too.
You notice a lot of increased response from the fans as well?
SR20DET240 wrote:I would recommend going with a higher output alternator rather than raising the idle though.
i agree with you 100%. you'll burn more gas raising your idle. a high output altenator should be the first upgrade for anyone who is into sound systems for their automobile.
Anybody know where to get HO alternators for the 240sx?
any auto electric shop should be able to find what you need.
-demetrius
BabyboyDeLa240 wrote:Hey About your UnderDive Pulley... well here is a site from the magazine Import Tuner and they have a 96 240sx with three bolt on and complete dyno's on the three(5Zigen cat-back exhaust, Injen Intake w/extension and the UR Pulleys)... The three combine gave over 20 hp plus and 20 plus torque... the pulleys gave some great power throughout the band... go check it out here is the direct link... So with the dyno sheets you now know what to expect and about how much. http://www.importtuner.com/tech/0210it_powerpages/
I am Technoman wrote:I do not believe them! No way, id say around 11 RWHP max with those mods...
BabyboyDeLa240 wrote:They have dyno sheets showing after each install. You should check it out. They have another POWER PAGE for a 95 240sx but they do not have in online. Its in the magazine. So if the dyno charts is not enough then i don't know what else to say...?
