Your cleaner put a film on the maf's hotwire which prohibiting it from getting a good reading. In the future, if you guys are going to clean your maf's hotwire, may I suggest 90% isopropyl alcohol as your solvent.sjbsuperman1425 wrote:well my car ran fine this morning, still doing the idle hunt and running a bit rich, so i said, well lets clean the MAF at school. i cleaned it, reinstalled it and bam, runs like snot!
it will idle but barely a 700rpms..i can rev it but wont rev past like 5k or so. left MAF unplugged to get home and wouldn't rev past 2k like usual. did cleaning the MAF (w/ MAF cleaner) mess it up? it was throwing Code 12 in Mode three..i got home, unhooked the battery for just a second or two, hooked it back up, and did mode III again and got code 55 but it still ran the same..im sure the plugs are ruined..is my MAF junk you think?
if anyone has an extra CA MAF, can you help me out? i really just need a car to drive to school thanks..
Its was intermittantly working, then i cleaned it, then it stopped working completlysjbsuperman1425 wrote:you mean you cleaned it then it DIDN'T work at all, or it worked good?
no kidding..idk im 90% sure the MAF isn't funked as i could drive it and it'd just run super rich, and i think only threw a code because i unhooked it sometimes..im going to go home today and reset the ECU, as leaving it the battery unhooked didn't work..then let it idle (as crappy as it does) and see if i get the MAF code.MeanGreenS13 wrote:i think you my friend may have worse luck with the CA than i do... wow
If it was truly bad, you'll get the "12" on your ecu. Other than that, becareful when cleaning it with a Qtip because too much pressure and you will break the wire and then you're screwed.sjbsuperman1425 wrote:From Progman in Running rich? thread:How did you clean the MAF sensor? It should have worked after you reinstalled it. no reason for it not to. I have plugged and unplugged a MAF on a running CA many times before. Perhaps its was problematic and it finally died?
i dont see any reason for the MAF to not be working. it idles like snot with it plugged it, but once i get going, it will boost at 3k and drive ok, but EXTREMELY rich. i forgot to mention this. so its sign enough for me to believe it is WORKING, but is just sending the wrong signal. Maybe this can be tied into what Dee had said? im going to clean it with Isopropyl Alcohol but dont know where to get it in the 90% range..all i can find is 70%..what do you guys think after this added information
in my eyes, i feel the MAF is still good, just there is something skewing the readings.
boost_boy wrote:If it was truly bad, you'll get the "12" on your ecu. Other than that, becareful when cleaning it with a Qtip because too much pressure and you will break the wire and then you're screwed.
Dee
Did you check the circuitry on your AFM's connector or the harness's connector? Your AFM could be very well be damaged if it's giving you a code 12.sjbsuperman1425 wrote:put ignition to on, code 55 in mode III, turned car on, idle at 1500, code 12 present. would a film on the wire cause an abnormally high voltage? i dont understand how using MAF cleaner would mess up my whole shiz..
It's dead, dude! I have an extra AFM somewhere in the garage, but let's see if someone can help you fist. If they can't, I'll let you have one for some gas money or something like that. Some things I can let go for the low-low, but some have to be treated like GEMS and I have to charge according to scarcity because once I get rid of something, there's no telling if I'll ever have a hard time finding that part for myself.sjbsuperman1425 wrote:well everybody, im thinking the MAF is dead cleared codes, and the code 12 came back right away. the electrical cleaner left a residue on my hand today, so i did the 91% alcohol which did NOT leave a residue. still...nothing! i didn't check the voltages as you said dee, but i know that the harness is good. looks like its time to buy a used one..
another thing though, that cap on the MAF, what is it for? i know if you take it off there is a spot to use a flathead screwdriver, but what does it do? just wondering about it.
Ca_Silvia wrote:I paid 80 for mine, i will let her go for 50+shipping. LMK
