Uas bag question
div1ne
Ladies and gentlemen that have uas bags on oem struts...how's the ride... How long has the struts held out for you...Any cons I should know about before jumping on them?? Thanks in advance
anotheraznguy
Car: 2005 Nissan 350z
1989 Nissan 240sx
2006 Infiniti M35
had them on my car for over 20k miles. Ride is similar to stock if you drive at near stock rideheight. Main downfall is that for the rear, you need to drill and weld a nut on the top cup to ensure that when you jack the car up, the bag doesn't fall out. Also, with this setup you shouldn't drive too low otherwise you can damage shock and ride will not be very comfortable since you have almost no air in bag.
