u13 headers plsss
General discussion area for the U13-chassis Altima
95ka24
Car: 1995 Nissan Altima
hey guys....im looking for a nice headers for my 95 altima.....will settle for used piece...cant afford the stillen right now...help pls..773-895-9248mods i have in my u13:aem cold air-costumizedobx-cat back-b&m short shifter-spec stageII clutch-16"big lip 5zigen..ngk ignition-tower bar-.....help plss
Cold_Zero
Car: 2003 Nissan Altima SE 3.5
2005 Nissan Pathfinder
Sorry man, can help you in that department. Have an 02 and 03 Altima.
Anyone help out a fellow Altima owner?
niceguy
Just buy an OBX header off ebay...around $200 shipped new. I had no problem installing it by myself on my '93 GXE...
Jeremy
altim8victory
Car: 93 nissan altima 5spd limited edition
You can buy the obx headers off of ebay but there may be some fitment issues that you may come across when you install it. But there minor & well worth the install for the extra HP gains you get in the long run.
95ka24
i was going to buy that OBX 4-2-1 headers a while back, then i read some negatives about it in this forum, that the welds are not so good.....it was months ago...but i think i'll take your word for it, since i wont be using the car for drag racing, then it should hold then.
altim8victory
The 1st gen built obx headers were garbage. But the 2nd gen ones, the ones on ebay now, are nice. The welds are much better, the mandrel bends are right on point and it no longer has the altenator and front engine mount clearance issue. Just about 1/2" of the block needs to be shaved down where the flange meets the downpipe other than that Ive had them for a yr no problems and im heavy with the gas pedal. Just make sure that your getting real obx ones and not knock-offs. There should be an upper and lower plate welded onto it that says o"High quality exhaust obx R racing exhaust" Heres a link to the seller i purchased from.
http://cgi.ebay.com/ebaymotors...wItem
95ka24
HEY...THX FOR THE REPLY.....SOUNDS LIKE YOU'RE REALLY HAPPY AND CONFIDENT BOUT YOUR PURCHASE....SO, I'LL GIVE IT A TRY.....BUT, IF YOU DNT MIND, CAN YOU TELL ME WHAT YOU MEAN BUY 1/2" THAT I WILL HAVE TO SHAVE ON ENGINE BLOCK!?
altim8victory
http://www.nissanclub.com/foru....html Theres a link here another forum...altimas.net with pictures...hope this helps.
Return to “1st Generation Altima Sedan (1993-1997)”
