U13 fuel pump
General discussion area for the U13-chassis Altima
Coops.N.94
Car: 1995 Nissan Bluebird (U13)
I had the fuel pump fail in my 1995 U13. I got a replacement pump, currently fitting it, I got the fuel tank access cover off. I have also got the fuel tank lid off, but I cannot find find the fuel pump in the tank visually. I also have a full fuel tank which probably does not help.
Coops.N.94
*Solved* so turns out I did not have enough light to see the carrier attached to the tank, for those interested, the level sensor unclips first, then the fuel pump.
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
:dblthumb:
Return to “1st Generation Altima Sedan (1993-1997)”
