U1000,B0020,B0028, and B142A codes
General discussion area for the L33-chassis Altima.
braddaboo
Car: 2018 Nissan Altima
My airbag light flashing code is 24 and the reading from my ABS & Airbag NT630Plus scanner gives me those codes in title. I’ve unbolted both driver and passenger chairs, checked harnesses and cleaned it with CRC QD electrical cleaner. Battery was disconnected. What I haven’t done is check wiring in seatbacks. Did both self diagnosing mode and off/on airbag reset trick. Clear codes on scanner does not work. Can I get some input please? MERRY CHRISTMAS!
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Same answer I gave you in that other forum, but if you're a skilled DIYer then this may help you out:
diy-side-airbag-fix-t630271.html
The codes vary from coupe to sedan and model to model, but yours are for both of the side airbags in the seatbacks. It's a particularly common problem on gen5 Altie sedans.
braddaboo
Your very much appreciated, thank you.
Return to “5th Generation Altima Sedan (2013-2018)”
