u1000 and u1001??
sirgeathan
Car: 2004 coupe g35 MT6
hey, i currently own a 2004 g35 coupe 6speed. I am having a issue with the car and the ECM. My car started to back fire and broke down on me. Had to replace all 6 coils, catalytic converter and ECM. My mechanic did all the work and also a programmer programmed the car. Had this problem twice and fixed it. Now I am getting a program where my car idles. also showing SES and when my mechanic checked it was saying U1000 and U1001 code. I am going to the check out with the infiniti dealer, but before that, i was wondering if any1 came across this issue b4. Your help would b very helpful. Thank you, Stephen
zozoka1212
Car: 08 Infiniti G35x
I think that is code for no connection. The ECU has conection trouble with other part of the car. Most likely with other sensors or modules.
asoomal
Car: 2001 Subaru Impreza L 5MT (Daily)
1992 Nissan 240SX SE 5MT w/HICAS (Being restored)
Yea, "u" codes usually mean a network connection problem or module related problems.
Check and see if the harness is properly connected, and also the OBDII port.
timmy0257
Car: 08 Infiniti G35 Journey 5AT
-R2C Intake
-interior LEDs w/ tag lights
-SBD grounding kit
-TBW engine cover
-Eibach Pro-kit
-JL Audio
Future Mods include GT-Spec strut bar & more.
what mods do you have?
sirgeathan
no mods other then replacing the coils and spark plugs. I went to the dealer today and they cheacked my car out. they told me that the grounding wires needs to be cleaned up. soo many in the car and its about 3.0hr work. they also said that was the cause for misfire and communication error. hopefully from the clean up, the car should be good to go. :) $480cnd with dioginostic and labour
timmy0257
-R2C Intake
-SBD grounding kit
-TBW engine cover
-Eibach Pro-kit
-JL Audio
sirgeathan wrote:no mods other then replacing the coils and spark plugs. I went to the dealer today and they cheacked my car out. they told me that the grounding wires needs to be cleaned up. soo many in the car and its about 3.0hr work. they also said that was the cause for misfire and communication error. hopefully from the clean up, the car should be good to go. :) $480cnd with dioginostic and labour
well if the grounding wires are not installed properly then that could be your culprit. that would be considered a "mod".
it would be odd that if you have had them in there a while and just started getting this problem.
kmckis1029
Car: 2016 Q50 RS400 AWD
2010 G37x w/Prem, Nav, & Wood (sold)
2005 G35x w/Prem C (traded in)
stock grounding wires giving a problem... interesting... lots of people dont believe grounding effects how the G runs... perfect example of why every car i have owned has had upgrading grounding.
I hope cleaning those wires and surfaces fixes your car.
timmy0257
-R2C Intake
-SBD grounding kit
-TBW engine cover
-Eibach Pro-kit
-JL Audio
oh! stock grounding. interesting.
sirgeathan
hey, i just got back from the dealer. they cleaned all the grounding wires and the U1001 code is still showing up. They replaced the ECM with the orginal 1 i had in the car and it actually went away. But unfortunally the car keeps to back fire. the dealer said the that cylinder #3 was not giving signal to the injectors. the problem could be ither the harness leading to the injector or the ECM. the are asking $590 just take the intake out and check the program.
telcoman
sirgeathan wrote:hey, i just got back from the dealer. they cleaned all the grounding wires and the U1001 code is still showing up. They replaced the ECM with the orginal 1 i had in the car and it actually went away. But unfortunally the car keeps to back fire. the dealer said the that cylinder #3 was not giving signal to the injectors. the problem could be ither the harness leading to the injector or the ECM. the are asking $590 just take the intake out and check the program.
Had to have my wiring harness replaced six weeks ago
Mine was replaced for a flashing air bag warning light
Telcoman
timmy0257
-R2C Intake
-SBD grounding kit
-TBW engine cover
-Eibach Pro-kit
-JL Audio
eek. telco, what was the bill on that?
zozoka1212
Left leg and right arm. LOL
Telco you need to get anew car. You piling up miles. Now you will start sinking $$$ in the car.
