lock or an U-Turn at low speed. I can hear a clicking sound , like click, click , click.
CV joint ?
Upper strut bearing?
Wheel bearing?
Winter tires/wheels?
Does someone already had this issue?
Thanks guys!
Thanks!PapaSmurf2k3 wrote:Usually if its a CV joint, it will click while turning far before full-lock.
I will verify this.
Do your winter wheels/tires have studs in them? NO STUDS
Are they any taller than factory tires? Stock dimesion
You could be hitting the inside of the fender or something. None
You can probably bring it back to the dealership for diagnosis (under warranty) if you'd want.
]I know that is my best solution, but since my basic 36 months warranty is over and probably this issue won't b be covered by the powertrain warranty , I am a little scared ... of the dealer estimate...
