u-joint replacement
maverickz32
Car: 1990 Z32
I replaced the clutch on my 1990 N/A 2+2. With the driveline out I noticed that the u-joints need to be replaced. the u-joints are staked in, and all the info I can find points to replacing the driveline for up to $600. Oriley's auto parts sold me joints PN 387. Summit indicates the same PN for my car.
Has anyone figured out how to install new U-joints in the driveline instead of replacing the entire thing?
Thanks for the help.
itsa300zx
Car: 1990 300zx NA W/TT swap
2011 Nissan Rogue S
2008 Highlander SR5
You need a pretty big press to remove/install them, should have it balanced once u joints are replaced.
New 1 piece DS are about $250-300
