u-joint question Please help
pejsa s-13
Car: 91 HardBody, 85 720
91 HB KA 5 spd
the u-joint that is closest to the rear diff is completely locked up!!!
are these joints servicable or do i have to replace the whole drive shaft???
need help asap
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
The last u-joint on the driveshaft, at the pinion yoke, is replaceable.
pejsa s-13
could you possibly explain how to do this?
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
You need a press or at least a vise.
Remove the driveshaftRemove the spring clips on the outside of all 4 Ujoint caps.Press the Ujoint out sideways off the driveshaft end, then the pinion yoke.
Replace.
A standard Spicer 1310 Ujoint should work. If you don't have the right tools for this, if you take the driveshaft to a driveline shop, Ujoint replacement is pretty cheap.
