U-Joint, Driveshaft, Vibration.. etc...
scyan
Hey guys, I heard that a vibration between 45 60 MPH could be due to the driveshaft u-joint/bearring if everything else is fine, how hard and expensive is this joint to fix or change ?
Daunttless
Message Av8ermech, she just changed hers.
scyan
How would I do that exactly ?
Daunttless
click on her name, she's a moderator, if you click on the underlined name of her after one of the forums she moderates it will open her profile and give you her contact info.
scyan
Thx, all done, I emailed her... Where would i get the reply now ? In the email I specified on my registration process I guess ?
Scy
Repo Man
Car: 2020 Frontier Pro4X
2003 Honda Accord
scy,
I had that problem on my Turbo Regal. It was not hard or expensive to fix. Pull the driveshaft and take it to your local joint/clutch type place and have it speed balanced and u-joints replaced. It cost a whopping total of $50 to take 110mph from super scary to smooth.
...my two cents is free...
scyan
Wonderful !! Thanks !
Scy
Repo Man
2003 Honda Accord
No prob. Let us know if that works and how much it cost you.
clearview
if you have an s-14 the driveshaft is non servicable. you can't replace the u joints. you have to get a new driveshaft. you might look into running a one piece shaft.a custom 1 piece would be about 375, nissan 2 piece is about 500
Nismo_Freak
Car: 89 Nissan 240SX
45-60 vibration can be a number of things... try inspecting your Tension Rod Bushings and suspension. Inspect your wheels for visable damage, which can cause vibrations. If you have aftermarket wheels often they can be mis-balanced and can cause speed sensative vibrations.
