type x wing owners help!
i2ice4m3
Car: COUNTERSTRIKE!
can somebody with a type X wing (either oem or knock-off) give me the distance between the screws of each standoff and also the distance between each screw on a single standoff? (i am assuming there are 4 bolts that hold the wing onto the hatch lid)so basically...the distances X and Y if o represents each bolt location looking at the underside of the spoiler.
- o<-------------------X-------------------->oY- o<-------------------X-------------------->o someone tell me if it's the wrong bolt pattern in the first place! I'm currently doing some body work and i just took off the stock spoiler (btw..that thing was a POS), which left a nice 10 holes in my hatch lid. i'm in the process of filling them and I need these dimensions to see if any of the stock holes match up with the type X's required holes in case i get a type X wing later on. thanks yall!
sohc90adel
Car: 1990 Nissan 240sx HB 5 speed Grey
just fill them up and do the holes later its much easier, thats what i did. the spoiler holes might be off by a little when you get it.
i2ice4m3
Car: COUNTERSTRIKE!
here's how i'm filling the holes:1. Use JB weld to "cold weld" small pieces of aluminum sheeting to cover up the holes from underneath.2. bondo to fill in the holes.
I would do it the right way and weld sheet metal to cover the holes up, but i dont have a welder and dont want to pay a shop to do it. This way is cheap and works surprisingly well as i can put a lot of force on the aluminum pieces from the top and it will hold fine(i havent bondo-ed over them yet). The problem, though, is that if i do get the type X wing (or any other wing), i'd rather not drill into the bondo and aluminum if the new holes happen to line up with the old ones. That's why i need the locations of the type x wing holes--if they happen to line up, i won't fill the ones they line up with. If they don't, i'd go ahead and fill them. Thanks adel for your help!
approximate locations would be of great help too.
sr20det
Car: Drifting, draging, silvia projects
sorry, i did eye measure :)
