That's the problem, I can't find a bulb small enough to fit into the kouki light hence the massive wiring harness I have. When originally installed, the koukis were extra lights in addition to the pignose so it wasn't an issue. Pignose is three, that is correct. Kouki is two. I currently have my turn signals running to them and have no running lights.zachattack_5491 wrote:Dude... stock pignose lights are both signal and driving lights. Cut the wires, and find a bulb with the exact same characteristics as the old one except for the new one needs to be smaller to fit inside the hole for the new housing. Wiring up some lights is not rocket science, ESPECIALLY when all the wiring you need is right there.
Edit: Grab the FSM and look at the wiring diagrams in the back. If you haven't looked at those I can understand why you're having trouble. There are 3 wires that connect to the bulb if I remember correctly, running power, signal power, and ground.
