type-h RFL....garbage?
ca18det240hatch
Anybody here have experience with ca18 and Turbo XS type-h RFL blowoff valve. mine just plain wont blow off, i have vacuum run to it, i checked and it is vacuum/boost.......doesnt blow off period
240 Trainee
I dunno, I have ridden in a WRX with one, seems the WRX people like them, sounded ****ing rad in the WRX with 20+ psi, lol
ch187
Car: 90 CA 240sx
try adjusting it? might be too tight..just a thought.
ca18det240hatch
its adjusted all the way out with none of the supplied "shims" in it.
nismoplsr
Can you move the plunger by hand?
I have a Type-H non RFL and never had problems with it not working.
Indecisive
Car: 1987 200sx Turbo
I had mine working on my ca18et(same displacement, smaller turbo) just fine.
Your vacuum source may not be strong enough. I had mine connected to a vacuum line that wasn't large enough and it wouldn't blow off.
I tee'd it with my brake booster and there weren't any problems. I even had to add 2 shimms because it would open and close idle.
it'll be on my ca18det this weekend, so I'll know for sure if it's working or not then.
slidecrave
Car: AE86, S13 CA coupe
if its not on too tight maybe the spring inside is just too much for your application.. which i believe is what happen with my blitz bov, but then i actually tried the rfl my friend had from the same vacuum source and everythin and it worked just fine.. so could be that
page02wrx
Car: 2004 350z
240 Trainee wrote:I dunno, I have ridden in a WRX with one, seems the WRX people like them, sounded ****ing rad in the WRX with 20+ psi, lol
txs leaks around 20psi dude
rfl's suck on anything with high boost, you should be fine with anything under 16-17psi..... around 18psi txs rfl's are KNOWN to leak around the valve
240 Trainee
Well, I dunno, he said he had an RFL, and it was rfl, and his boost gauge was going past 20.
c-rad
Car: 1991 Nissan 240SX w/CA18DET
HKS ssqv... no adjustments, no problems.
jt15833
Car: 95' 240SX
ive got this cheap bov on just because it came with the IC pipes and wouldnt blow off. i took off the top to see the spring and they had 2 springs in there, i guess it came with a low and a high and they put both in. maybe its something on the inside, check it out most bov's are pretty simple.
page02wrx
Car: 2004 350z
I never said it acted like a wastegate that completely shut the boost off.... you'll still boost whatever you want your turbo is just going to work harder and you'll run a bit rich..... cause you're losin air through the BOV
Search for txs rfl on nasioc.com , you'll see it has pretty bad reviews when it comes to a high-boosted subaru.... most people who use them are running stock boost.
