BadMojo »
https://forums.nicoclub.com/badmojo-u5205.html
Mon Apr 05, 2004 4:52 pm
If I had my engine out of the car, I'd replace both tensioners, guides, both chains, thermostat, water pump, oil pump, oil seals...everything that could possibly wear out.
If it's an otherwise healthy but high mileage engine, I'd replace all the stuff that's a pain in the *** to fix when the engine's in the car.
I don't see why a problem with the upper chain would necessarily indicate a problem with the lower one as well. Still, how would you feel about trying to replace the lower chain if it starts making noise 6 months from now?
