Red coupe »
https://forums.nicoclub.com/red-coupe-u19771.html
Tue Mar 21, 2006 7:41 pm
drip maybe a teaspoon of oil into each cylinder and check again...If compression rises it could be piston rings...
Also have you checked the coolant/oil levels? Headgaskets are often accompanied by coolant leaking into the crankcase causeing milky looking oil...start it cold with the radiator cap open, If it wont start have a friend watch while you crank, a blown head gasget can also cause buble in the radiator...
If you have access to a compressed air source you might try renting a leak down tester from the autoparts store. It is simmilar to a compresion tester but it pressurises the cylinder, that way you can listen for a leak...Make sure the valve on the cylinder being checked are close(engine off). oil filler means head gasket, intake = intake valves, ect. ect....
