Two questions on the Rogue
Juelze
Car: 2010 Nissan Rogue 360 AWD
Question#1. I checked in the user manual and couldn't find a solid answer. Can the AWD lock ONLY be enabled when stopped? It says if you're going at a high rate of speed it will switch it from AWD Lock to automatic and that the AWD lock light will go off. It also mentions not to engage it when decelerating or backing up. But if I'm going 5-10mph and hit AWD Lock, it doesn't engage. Is that normal?
Question#2. Do all Rogues come with TPMS? I'll have to double check, but I swear I do not get a TPMS light that comes on when I start my car (when it tests out all the warning lights). If they call come with it, where should it light up as maybe I'm missing it?
Thanks!
Juelze
Leo2005
For the first question it is normal just the way you described. It is made for safety on awd system so it won't get damaged while driving on high speed or turns. Awhile ago I checked F-150 pickup and it says in the manual do not make any turns with 4wd on so it's pretty much a same reason.
Second you do have TPMS sensors but I don't remember if my light came on at all until I had a loose air. Not a good idea but you can try to lower the pressure in 1 or 2 of your tires to about 25 psi and drive for a few minutes with speed over 25mph then you should see a light.
TonyN
Car: 2010 EX35 "The Baby Wagon"
2010 Camry SE "The Beater"
1994 Supra Turbo "The Weekend Warrior"
cant lock the awd and the TPMS indicator is in the center between the two main gauges
Return to “Rogue Forum”
