bourque_john »
https://forums.nicoclub.com/bourque-john-u150860.html
Thu Jan 07, 2010 3:14 pm
Hi there. I'm new to the forum and really to forums in general so please be gentle.
1; I've recently discovered that the ball joint on the left front needs to be replaced. Bell tire told me 500 & change to do it but I can get just the ball joint from pep boy's for 44$. My question is without having a press, or all that much in the way of automotive tools, Would I be better off just having belle tire do it or is this something that can be done in a drive way. While it was on the hoist when they showed me the problem I could see what needed to be done to change it out and I think I can do all of it right up to the popping out and popping back in of the ball joint on the lower control arm. That's the main spot I'm concerned with.
2; I'm wanting to swap out my driving lights above the HID light's. I'm not entirely sure how to even get at them to pull the bulb. Do I have to remove the whole headlight assembly or should I be able to pop off the back cover without doing that??
Also Tat2 has more or less the same question about the headlight as I do but he has a picture that points out the light we're talking about.
I appreciate any help.Thanks.
