I have the same problem. When i start the car it relies on power from the battery untill i blip the throttle also.. then the alt takes over. But you guys are right. The alternator was not made to handle 2 or more e-fans and other electrical loads we put in. I also found that my Nistune consult disconnects when the alternator is charging. Giving me the feeling the quest alternator is the way to go. As for a battery mine is fresh. Its a mini battery also so i could keep it in stock location.jrb92se wrote:hi i have an rb25det in my 240sx, i recently had the a/c hooked up and installed flexalite fans but now when i start the car it seems like it doesnt have enough elctrical power until i blip the throttle then the rpm at idle comes up and the fans seem to power up and run a little faster also some times when i am driving at night the headlights seem to vary in brightness, they get dimmer or brighter when i hit and release the accelerator the dash lights also sort of flicker like that too. ive checked the grounds and everything seems in order but i cant figure it out (i havent had my alterntor tested yet). since ive installed the fal fans the car seems to be running way to cold it rarely gets over 85 degrees celcius on the pfc controller read out..
Modified by jrb92se at 3:37 PM 12/6/2009
