After you install front shock tower braces you will notice that the chassis is still deflecting a substantial
amount [after all it is a luxury car].
The frame rails can be reinforced internally with 2 part structural foam. The Q already uses some in entire A
pillar, upper B pillar, and a partial stiffener running across the pan under the B pillar tying the two sides
together....Good but nowhere near enough!
Each kit fills approximately 1 cubic foot of space...you will need 5 kits to do the job correctly and this will add
8-9 pounds to the weight of a Q. http://www.itwfoamseal.com/auto_after_o ... market.htm
Both are by Q45TechPS: my car handles an order of magnitude BETTER than Brand NEW without OEM soft tires ......with them
it is tremendous but a pain to keep them balanced.
I have spent over $5,000 in parts cost alone experimenting with every changeable aspect in every combination [3 different rear sway bars, 2 different front bars, stock and lowering springs [even front/rear
mixed], bushings, rear sub frame, new front cradle, and suspension arm replacements.
Not to mention hand making rubber bushings and isolators out of 5 different durometer rubber stocks. Extra
vibration dampers on exhaust....have a few more tricks using urethane suspension foam and strategic
sound deaden in doors.
Q45Tech do you mind going into a bit more detail about this: Such how big of an improvement might be gained by doing this?, where to get the foam?, How to install it?
