silviasgp06 »
https://forums.nicoclub.com/silviasgp06-u61439.html
Sat Mar 22, 2008 2:53 am
does the ECU read the knock sensors independently or not, if so read on.
what have you guys done about monitoring knock with a safc, since there are 2 sensors on the car and one receiver wire on the safc. I dont know a whole lot about electronics but i do know there is stuff out there that isn’t costly that will allow something to have 2 or more wires connected to one wire(for monitoring purposes) without cause the original two to be connected.
something that taps into both knock signal wires for the safc without fusing the 2 signal wires
or does it even matter about fusing the signal wires, i would think that if the computer reads the signals independently, fusing the seniors would cause the ecu to read double the knock.
if connected together cause of the on safc receiver wire:-say if only cly 1 was knocking then the forward and rear sensor will read knock causing the ecu to adjust thinking there is knock in the back and the front of the motor.
so does the ecu see knock from both sensors independently or not?
sorry if long and slightly repetitive-
