MaineExport »
https://forums.nicoclub.com/maineexport-u157.html
Thu Oct 10, 2002 2:52 pm
I've seen a twin-V8 Jeep. Front engine drives rear wheels, rear engine drives front wheels. They removed the engine, transmission, transfer case, running gear, and stripped it down to the frame. Removed all motor and transmission mounts. Welded mounts front and back for two 302's with trannies. Cut the tub, to fit over the rear engine, and trimmed the firewall to fit the front. The engines were from 2X4 Ford trucks I believe... and they used the stock Ford axles and everything on the Jeep. The only real trick was linking the throtte, and trannies to syncronize, and reversing rotation on the front axle. But it was TOTALLY unstreetable!!! On pavement, the tires would chirp every few seconds, becuase they were spinning at ever-so-slightly different rates. In the mud.... it kicked A$$!!!!!!!! 44" Super Swamper TSL Boggers helped as well!
