bone_stock_240 »
https://forums.nicoclub.com/bone-stock-240-u55171.html
Tue Apr 17, 2007 3:11 am
yah, that would suck after going through all that effort changing all that other stuff. Look on the bright side though, at least most ofyour fuel system is now new and won't give you as much trouble. The same thing happened to me after I swapped my clutch. We were beating ourselves over the head trying to figure out what we did that would cause the engine to idle really really rough, have no power, and run really rich. I spent ages going through the vacuum lines and was completely stumped. I even started to pull the transmission again, even though I couldn't see the connection, that was the only thing that we messed with. The person that I was working with decided to pull a couple of the plugs to see if that was causing the problem. He pulled 1 and then 4 and nothing happened so he concluded that that wasn't the problem. So then I pulled 2 just for the hell of it, and the engine shuddered like hell and almost died. Same thing with 3. It was pretty funny how the 2 plugs he pulled were for the 2 cylinders that weren't already firing.
