blacksrjdm »
https://forums.nicoclub.com/blacksrjdm-u52167.html
Wed Jun 17, 2009 4:41 am
Ok, so your getting bad clutch chatter, because the flywheel needs to be resurfaced or replaced. Remove the trans, because you need that shim inbetween the two for the starter, and alignment for the trans. Also, you could replace the master and slave cylinders for optimal use.
I would say you need a flywheel, put the shim back in, and make sure the hydraulics are working up to par... The shake or jump you are feeling is the clutch chattering on the flywheel on engagement.
