Twin turbo vh45 ute
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
CNBRacing
Hi guys im building a twin turbo VH45 nissan ute i thought you may be intrested in.
Ive allready planned the whole project so i have answers to any questions
http://img100.imageshack.us/im...o.jpg
hannibal
Car: Red Line to Glenmont
Welcome to NICO!
Is this in a Patrol? More specs and pics please!
CNBRacing
its in a 2000 shape Nissan Frontier ute. running factory auto trans with 3000 rpm stall, trans has been rebuilt with more clutch packs and has been manualised.twin garret turbos with twin intercoolers and twin plenums.I will have to take a few more pictures. As pictures say more than words !
http://img224.imageshack.us/im...s.jpg
Ezekial
Car: 2001 Nissan 200SX S15
where are you located?
CNBRacing
Im a kiwi from New Zealand.
kiwirota
Car: mazda familia
what are you doing to the engine and what sort of power are you hoping for??
CNBRacing
pmpmstrb
Any chance of getting some pics of the manifolds? Or better ones of them installed?
Jerminator96
Car: 94 Chevy Camaro
Just a suggestion, but air shouldn't have to bend that much to make it into the runners. Now it won't matter so much on a forced induction vehicle, but it will help some to give the air a straight path.
Ignore the short runners (unless you want to hear about dual length runner design). The one curved runner is just showing the possibilities for different entry angles into the cylinder heads.
My $.02
Jeremy
Mettler
Car: HR31 GTS-8 coupe, VH41/45 Hybrid Transplant
Huh ? His manifold doesn't look to me like the air has to bend any further than the designs you've just linked.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
What I find interesting is that one bank's manifold is isolated from the other.
Anyone clue me in as to why?
Jerminator96
My design really needs some explanation as it is just a rough rendering. Forget about the short runners that run straight down. Imagine the plenum's positioned over each cylinder head. The runners make a straight shot for ~10" into the intake port. That is long enough to smooth out any turbulance, it's also great for torque.
The design he has mocked up appears as though the runners make an S-bend into the head, I don't see how that could be as straight as my design.
Edit: Does my drawing appear as a link or a picture?
pmpmstrb
Just to clarify, I meant exhaust mani's.
Jerminator96
Let me try to explain my design better. Here is a picture (albeit a bad one) of the intake manifold on a Ferrari F40.
The long runners between the plenums eliminate any turbulance as they run straight into the intake ports.
Edit: That's actually on a 288 GTO Evoluzione
Modified by Jerminator96 at 10:12 AM 8/19/2006
CNBRacing
pmpmstrb wrote:Any chance of getting some pics of the manifolds? Or better ones of them installed?
ill post some more pics of the exhaust manifolds soon. My intake manifold has balance tubes on it, picture ive posted was of it still being made. I dont care to much about all out performance , as long as i can do big skids in it im happy.
Jerminator96
CNBRacing wrote: ill post some more pics of the exhaust manifolds soon. My intake manifold has balance tubes on it, picture ive posted was of it still being made. I dont care to much about all out performance , as long as i can do big skids in it im happy.
So long as you have your priorities straight
hannibal
The only S turn I can see would be in the stock lower manifold pieces. Eliminating those runners and using custom runners from the plenum to the head could help.
The only other advantage i can see in Jerminator drawing is that the cross flow manifold could allow you to keep the same length runners and still clear the hood.
Overall, this looks badass! Cant wait to see the exhaust manifolds...
hannibal
just something to add. I saw CNB's thread on nissanv8.com. I forgot that the injectors sit on the lower runners. I assuming that played a role in the decision to keep them.
http://www.nissanv8.com/viewtopic.php?t=34
I guess you could still do the direct plenum to head runners if you included some custom injectors bosses. But then you'd have to worry about the angle, etc, something thats already designed into the stock runners.
CNBRacing
For those of you who havent seen the pics
http://img177.imageshack.us/im...2.jpg
hannibal
That looks awesome!
pmpmstrb
I wish I had that kind of room under my hood for those manifolds. Any word on the turbo manifold pics.
Mettler
Er, he doesn't have room under his hood for those manifolds either, they stick out about 300mm-ish :p
sijoko
Car: Black 1994 Infiniti Q45 Turbo, Pearl White 2014 Maxima Sport
Excellent! What size throttle bodies are you using?
I wish someone would make a low profile aftermarket plenum for the VH. I am sure the stock "spider" plenum does a good job but it is such a pain to work on the engine with it on.
pmpmstrb
Mettler wrote:Er, he doesn't have room under his hood for those manifolds either, they stick out about 300mm-ish :p
Oops, from that weird above angle it looks like it would clear.
Mettler
Probably because of the back face of the plenums being at that diagonal or something. Yeah I see it too o_O
Return to “VH45DE / VK45DE / VK56DE Forum”
