and i'll bet this is the reason why it blew up -------> DODGY ECU SETUP OR TUNE(R)!!!!Mettler wrote:When you say standard but rebuilt, do you think he meant standard including stock rods, pistons, etc ?
If that's the case... I may well be interested in supercharging/TT'ing mine afterall ! I was just concerned about exploding the engine after talking to a guy from NZ who went through five motors getting the TT setup to work.
So that VH45 in the Nizpro boat is running stock pistons and factory head gaskets? Wow! That sounds too good to be true.Ezekial wrote:The standard pistons are fantastic! Flat top, no dominant hot spots prone to detonation. Moly coated i believe as well. The top ringland is decent size as well!
The standard conrods are huge! oil squirters from factory also.
they most definately do support VVT. triggered via rpm. yeah that is retail priceMettler wrote:Thanks Ezekial, I could swear you're trying to talk me into it I'm from NZ by the way.
I don't think the Microtech support the VVT (VTC according to wiring diagram?)... I sent them some enquiries and the ECU they recommended to me is the LTX12, which I think costs closer to $1500 AUD.
like i said its not as if the standard pistons are crowned or have any prominant hot spots so with good tuning there is no reason why they woudlnt survive. as for the head gaskets if you are worried, ACL in australia make triple layer metal head gaskets for them for under $100 AUD / bank. available in a few different thicknesses.sijoko wrote:
I know that the Japanese usually measure the trapped or corrected compression ratios on their engines, but from everything that I have read, the corrected is always less than the static compression ratio.Ezekial wrote:.
Yes i have the figures at home but the 10.2 was a slight exaggeration.
Also, the key is the 68 degrees ABDC closing inlet cam.
ok so yes it closes at 48 and switches to 68 around 1500 rpm or so and then will switch back to 48 after peak torque or there abouts. I believe Q45tech has written something about this.sijoko wrote:
Now, maybe the VTC will cause the engine to act like a 10.2:1 ratio at certain points and that could be reason for the higher than static ratio. Could the reason for the 68 degrees ABDC be due to the valve overlap with the VTC setup?
surely a street car suffers less hardship than a race boat engine that is in excess of 7500 rpm for minutes on end?maxnix wrote:Yeah, but one thing to remember it is quite one thing to build a turbo engine that is at WOT most of the time vs. one on the street that cannot suffer lag at any rpm/load and relies on water to air cooling.
In the cooling department, no way. A boat can bring in fresh cool water to cool the engine whereas a stock motor has to do it by "conventional" means... Even by using water/water heat exchanger (which is what a lot of salt water boats use to prevent corrosion, especially on aluminum engines) youll be cooling with 70-80* WATER, nad not 80* AIR... If your running fresh water, you can pump fresh water right in.Ezekial wrote:surely a street car suffers less hardship than a race boat engine that is in excess of 7500 rpm for minutes on end?
Wait a sec, does the factory VH41/45 have inner valve springs at all ?Ezekial wrote:wes ... i cant see the valvetrain causing a problem with running high boost. its the rpm that will be killed. like i have said i am just using GTiR SR20DET inner valve springs with the standard outer valve springs
Yeah... Thats it.. However I wouldnt install them on a N/A motor..Mettler wrote:Do they have a higher spring rate and thus additional prevention of valvebounce ?
no the VH45 does not have inner valve springs at allMettler wrote:Wait a sec, does the factory VH41/45 have inner valve springs at all ?
What benefits are to be had by installing these ? Do they have a higher spring rate and thus additional prevention of valvebounce ?
Can the additional force cause other problems, like the valves hitting the seats harder, increasing the wear ? Or wearing our the roller rockers quicker ?
If not, then I see no reason why I shouldn't immediately get some !
the head studs and inner valve springs are all i have come across so far. GTiR SR20DET though ... not the normal run of the mill sr20 engineMettler wrote:Interesting read, thanks. I'll probably install the inner valves at some point or another.
In what other ways is the SR20 engine similar to the VH motor ? I've heard more and more about the two engines, enough now to believe they're very similar in architecture and potentially share a number of parts.
