sapix @ RHIT »
https://forums.nicoclub.com/sapix-rhit-u1947.html
Sun Dec 08, 2002 8:51 am
okay, I'm probably wrong here, so someone correct me, but...
The injectors for the SR20 are side feed and the KA24 are top feed, did I screw that up? Maybe its just because its Monday morning.
I really don't want to tell you to run without an intercooler, but at around 5 or 6 psi ::grits teeth:: you should be fine. If something bad happens though, don't blame me, cooling the air will benefit you. It will make it safer to boost, and have more power.
Back to injectors, I think the KA injectors are around 280cc/min, to get much more power I think you'll want to upgrade to 340cc/min (did I screw those numbers up?) Well, I'm pretty sure I feel like a fool this morning and I'm probably giving all kinds of bad information, so I'm just going to quit now.
Hope I didn't screw up too bad, but if I did, someone please correct me.
