Twin Turbo RB25 in S13 lots of pics.
driftin_galant
Car: cars
SI RB25R34 twin turbosVi-Pec ecu with Map conversionTomie 256 camsSubaru 500cc injectors
leesredgt
Car: 1992 Toyota MR2 N/A
1991 Toyota MR2 Turbo
Again very nice car.Is that a RB25 stamped on the front cover instead of the normal RB26? If so i want one.
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
nice setup
Cjmartz2k
Car: Hunting for a '89 GTR now
leesredgt wrote:Again very nice car.Is that a RB25 stamped on the front cover instead of the normal RB26? If so i want one.
Nope, he cut the "6" in RB26 to make it into a 5, just like I did.
Real clean setup man. I'm surprised at how well cutting a hole in the timing cover looked for the VCT. That black crinkle? paint is awesome.
Neejay
VERY nice and clean.
"Vi-Pec ecu with Map conversion" any more info on this?
StricNyne
wow, how did u mate the manifolds ? also i got oil line issues on turbo returns hitting steering ( -10an) and it looks like your not using vct, i have a fix if your interested.
Carl H
curious you guys took to the vi-pec ecu...i know it was touted all to hell on SAU.ive poked around the software some and wasnt sure i liked how it was setup.
ANVIL
Car: RB25DET S13.5
nice! more and more cleaner rb swaps now. back when i was first swapping lots of rigged, and failed/given up projects.
mattblancarte
Car: 2005 BMW M3 Comp. Coupe
awesome yellow-carbon cover! where can you pick those up??
Cjmartz2k
StricNyne wrote:and it looks like your not using vct, i have a fix if your interested.
Why do you say that? He's got the VCT thingy on the front of the intake cam gear (hence the hole in the RB26 timing cover to make it fit) and the solenoid is sticking out from the side of the motor. What's your fix though?
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
Very Clean. I approve!
MATTs14
Car: Red 1995 Nissan 240sx
Extremely clean build. We need some more pics and definitely a video.
SullivanRacing06
Car: r32 gtst, 06 350z, r32 gtr, rs4 steaga, 04 350z, f350/6bt
very nice!
myS13wantsaVQ35
Car: 1990 240sx / 1997 2dr Tahoe
sweet!
fast_s14
Car: 94 300zx
Very clean and detail install!!
myS13wantsaVQ35 wrote:sweet!
Why do you have your signature picture so BIG?
StricNyne
looks like nothing plugged into it, could be my use, just get the plug, and tap the rpm signal from ecu, and use a rpm activated switch like the nitrous ones i got msd digital one for 100 bux
Cjmartz2k
StricNyne wrote:looks like nothing plugged into it
Yeah, but neither are the injectors, intake, etc. I'm guessing if he went to the trouble of cutting a hole in the RB26 timing cover, he's planning on plugging it in. On a side note, Do you think you could run something like a shift light for the RPM switch? I've got a summit one with an adjustable knob on the back. I could use that and be like the honda guys adjusting my "VTAK" yo!
