jamesmost wrote:My man Slim (450zxtt) and i had a conversation and he certainly can and will build a TT Q and or a Manual Trans. He is the real deal , as well feel free to buy a ttz w/a blown engine and let him 4.5L tt it up. the numbers we spoke about were very reasonablejames
Sounds interesting... The way I see it the hardest part would be getting custom exhaust manifolds for the turbos and then finding enough room to flange the turbos off of them. I'd just go with small GT28R's, dual ball-bearing for super-quick spool up, or if on a tight budget just some cheap T28's. It'd be a tight fit, but there should be enough room for the piping under the hood and there is plenty of room up front for a FMIC. Drill and tap the block for the oil lines, then the only other part needed is the JWT boost program. The stock injectors should be good for like 400rwhp at low boost.
So how reasonable were the numbers??
