krayton wrote:the RB has a pretty hefty return line.
but technically wouldnt that suffice? if you T the feeder line, arent you going to still push the same amount of oil to the 2 turbos as compared to not Ting it and running a single turbo?
hypothetically though if that was incorrect, couldnt you get the turbo specs and run a oil restrictor to cut back on oiling to make that single return acceptable.
im just looking at other ways of doing it, but madschientist is right, thats gonna be the best way of course. so if you have the resources to just put another return at the top of your oil pan then have at it.
look at it this way; the feed line are rising rate pressured relative to the rpm. tee-ing off the source would not be a problem at all; especially ball bearing turbo, they have built in restrictor to keep the pressure down low.
the return line are not pressured, it's drained by gravity. the size of the return port is sufficent for a dual setup. have you compare the AN-10 to this port? the an-10 is pretty damn small and they did not have problem with oil draining. go for it.
