No gain with key as oil flow will be the same with the OEM pump. Woodruff is the word, I believe.Ezekial wrote:My engine suffered from oil starvation. Considering the state of my bearings ... i believe a woodriff key for the oil pump crank sprocket will fix this!
BTW The VH45 does have piston squirters. They are on the side of the conrods ...
Are they really designed to hit the bottom of the piston? I thought it was just to lubricate the cylinder walls.
Modified by maxnix at 9:32 AM 2/11/2006
