RRRRB wrote:Werid you guys dont have creep... i had twin 38mm MVS gates and it creeped terribley with my 6766, it was fine with the GT30R
I ended up installing twin MVR 44mm gates and its better, mine are vented externally though..
Manifold design makes all the difference..
Its suprising that twin 38's wouldn't do the trick, I always thought twin 44's were overkill on most setups (although I did go twin 44's with mine). However in some manifold/turbo, I believe back pressure in the manifold is a key contributer to wastegate flow. This goes along the lines that exhaust (fluid) will follow the path of least resistance. If manifold back pressure isn't very high compared to post turbo exhaust back pressure, then exhaust is less motivated to take a sharp turn down a wastegate runner. That being said, I imagine your 6766 flowed quite nicely and had relatively low back pressure compared to your GT30R and therefore you started to see creep issues.
It would be interesting to see a before/after dyno graph with the wastegates vented and recirc'ed to see the difference in boost creep/power.
