Twin Fuel Pumps, who's done it?
GTR PrYdE
Car: 1993 Nissan 240SX, 2003 Evolution VIII
I've read a few people that have done it, but no "how-to" or premade ones are available
Post up your twin intank pumps or Intake & Inline pumps setup!
A how to would be even better!
Thanks
-Devin
CSUPUEBLOTIM
Car: 1992 240sx Sr20det Coupe Silvia Front
ugh if you run them inline on a single fuel rail system then you will only be able to flow the capacity of one pump. I believe the "two pump" setups are for like 2 separate fuel rails, something on like V blocks so you get the extra fuel for needed for the hp.
xX RB Xx
Car: SE3P, FC3S, FC3C.
you mom has twin intake pumps..
Reno
Car: 89 S13, boosted.. RAWR..
xX RB Xx wrote:you mom has twin intake pumps..
pauliedrft
Car: 91 240sx
There running 3 pumps on supra s. check out supra forums im sure one of them have a write up of it .GL
Flicktitty
Car: 1989 Nissan 240sx 2JZ-GTE Swapped
1994 Toyota Supra
2019 Lexus GX460
1992 Lexus SC400
i'm running a single walrbo for now, i plan on upgrading this year to a dual or tripple walbro.
i will be following this build.http://www.2jzswap.com/vbullet...=2378
driftin_sr20det
Car: 92 Coupe
Shouldn't be too hard. I could probably make something for you. I think I have an extra assembly lying around here somewhere. I would just plan on running a an-6 or bigger fuel line from the pump to make running 2 pumps even viable.
GTR PrYdE
Thanks for the info, the 2jz swap stuff is pretty good too, we need a write up! Or someone needs to start making them and selling them.
driftin_sr20det wrote:Shouldn't be too hard. I could probably make something for you. I think I have an extra assembly lying around here somewhere. I would just plan on running a an-6 or bigger fuel line from the pump to make running 2 pumps even viable.
A drop in setup?? Thanks
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
CSUPUEBLOTIM wrote:ugh if you run them inline on a single fuel rail system then you will only be able to flow the capacity of one pump. I believe the "two pump" setups are for like 2 separate fuel rails, something on like V blocks so you get the extra fuel for needed for the hp.
This is bad info, you can run in parallel for increased flow rate, and mild redundancy. Its not a bad idea, but when aeromotive makes pumps to feed 1500 NA horse from a single pumps it just makes sense.
GTR PrYdE
You can run Walbro's in dual intank, dual external, intank and external in parallel, and intank and external in series....
I just didn't reply to the first several posts as they were complely useless and cluttering the thread.
Xdisaster240sX
Car: S13 Hatch, R32 GTS4
like your moms dual intakes?. sorry i couldnt resist.
EfiniRX7
Car: 93 FD3S not going anywhere, 2003 E46 M3 traded, s14 sold, 2010 camaro sold, now another kouki s14, FD did go somewhere, Now a 535whp rotary Kouki s14
Im running dual in tank walboro 255's on my FD. I used a y-block, submergible fuel hose, and a -6 an 90 to run my wires into the tank. The twin pump set-up works great feeding my 1600 secondaries.
naz
Car: 1990 300ZX TT with J-Spec Motor
lol
SullivanRacing06
Car: r32 gtst, 06 350z, r32 gtr, rs4 steaga, 04 350z, f350/6bt
im running twin in tank walbro 255s in my s13.
a single walbro maxxed out on me under 425whp
GTR PrYdE
do a write up!
