dareo »
https://forums.nicoclub.com/dareo-u8796.html
Tue Sep 30, 2003 10:53 am
If it was to be cheap, one could just take maxima clips and weld it up to a midsection, reverse the steering on the rear. if the car weighs less than 3000 pounds its all good. The point of dual engines is for the most bullet proof type of AWD i can think of. theres no heavy transfer case, or even RWD power loss. Two frontwheel drive engines, but one happens to be in the back. if you've seen the twin engine turbo'd Tiburon run a 10 second 1/4 on stock street tires, you can see the inspiration behind my supercar.
The speed potential of a light twin engine car with massive traction blows my mind to even think about. 1000 horse per axel? Moving 3000 pounds? 3 pounds per horsepower? I could see a 4 wheel burnout started at 100mph. it would be awesome!
If it was street legalized, running one engine and shifting before it boosts would net over 20mpg in the city as well. It would be a frankenstein supercar for sure.
The frame would cost probably 10k to R&D and have made, but lets use alumanum instead, titanium would probably cost a buttload. The engines and trannies could be had and built for probably 10k each. That puts us at 30-40 grand for a frame with engines installed. throw another 20k at some CV joints, hubs and struts, some massive brakes and a huge wheel/tire combo. Spend the rest of the 100k on guages, fuel tank and pump and interiour and that stuff. Then go find somebodies lambo or ferrari and show them what a 'Nissan' can do. If they can have a V12, why cant i have two V6's?
