Tweeter positioning
Discussion forum for body kits, repair, modifications, interior styling, Audio / Video and internal/external lighting.
harp00n
Car: G35x '07
I have '07 g35x sedan. Some time ago I put the aftermarket tweeters (MB Quard) + crossovers to the factory places.
How do you think, maybe It would be good for sound positioning, if I'll make podiums with the tweeters so they would look a little bit to the driver (the left one) and to the passenger (the right one)?
Because now, the left tweeter plays to the edge of the moving gauge cluster.
pfarmer
Car: 2008 GXS with technology package
harp00n wrote:I have '07 g35x sedan. Some time ago I put the aftermarket tweeters (MB Quard) + crossovers to the factory places.
How about on the dash itself right in front of the defroster vent. Put in 4 of them and leave the originals in place. Impedence match them. I don't really think it is all that necessary if the tweeter used is a wide dispersion type.
Perry
smockers83
Car: 2006 G35 Coupe
Personally, I don't think it's necessary. When you have a surround sound system, not all the speakers are pointed directly at everybody.
pfarmer
smockers83 wrote:Personally, I don't think it's necessary. When you have a surround sound system, not all the speakers are pointed directly at everybody.
I don't think so either as I believe most aftermarket tweeters are wide dispersion. Woofers are almost rarely an issue, midrange maybe. But in this car you have a lot of plastic so I don't really see much of a problem, most items low mounted in the doors are not the type to be an issue, those mounted higher are typically not a problem due to dispersion.
Perry
harp00n
Car: G35x '07
Well, better late, than never:
Tweeters are MB Quard with additional crossovers (2 level filter), hidden in the doors.
RichiePoor
Car: 2006 G35 Sedan
They look great !!
pfarmer
harp00n wrote:Well, better late, than never:
Necessary or not, they look good and probably sound good as well. What did you do to roll your own mounts?
Perry
harp00n
Car: G35x '07
Perry
Thanks! They sound good, really.
The bodyshop did it for me. They used some type of joint filler with the stock podiums, and then painted to the factory black color.
pfarmer
How much? I like them.
Perry
Return to “G35 and G37 Interior, Exterior and Audio”
