BaliLover »
https://forums.nicoclub.com/balilover-u6785.html
Sun Jul 10, 2005 10:45 am
After installing my Megan racing coilovers, I started noticing a clunking or twanging sound from my front end every once in a while, like when I went from reverse to forward, etc. I assumed it was Tension rods, so I replaced them with an adjustable set from PowerTrix racing with bearings, making sure they were leaning in the right direction as per the insturctions. I also replaced my front ball joints while I was there since they looked really bad.
Now I have a twanging noise in the front end almost every time I come to a normal stop, and sometimes when I go over largeish bumps.
I was told it could be Tie rods and ends, so I ordered a set from SPL but they're on backorder and I probably won't see them for at least another 2 weeks.
Is there ANYTHING else in the front end that could be causing this? The noise is actually more noticible now that I replaced the ball joints and Tension rods, and occurs more frequently.
