TW: 13" Rotors, Caliper Bracket
Jookmasta
keep us posted as to if u pursue the q45 path...............there are quite a many of us running that upgrade as it has been proven to be more cost effective and less issues with wheel clearance........
Timtiminy
Car: 89 240sx fastback
doing brackets for the q45 setup would go against what you just stated, it would be adding to the cost and you would not have the wheel clearance anymore. but i will still look, shouldn't be a problem. To keep it somewhat cost effective i will probably keep it just for the cobra rotors.
Maine_240
Car: 97 240sx - 87 Conquest TSI - 00 ZX900 - 05 KTM 250sx -04 Honda Rancher
Hey Tim Timmny
very interested in the VR4 Brackets
Please PM me the info
or Email
[email protected]
Thanks
Koren
sil80drifter
Car: 1990 240SX Hatch
Hey sorry to undig this, but did anything ever happen? did the brakets get made? have people tried them out? any feedback? are they still being sold? bump!!!
sil80
sil80drifter
anyone?
JPsNissans
Car: 04' SE-R Spec V, 95' S14 240sx
Argh, I'd really like a set of those R33 caliper brackets for Cobra/350Z Track rotors too. Anyone else make something like that?
silvia95
Car: 95 S14
I would buy a set of z32 brackets now! The last thing I need to put z32 calipers on my car is the rotors. Let me know if you are still going to make these.
Timtiminy
Just to let you all know. I have the Cobra/z32 brackets and i am just waiting on the hub rings. I'll update as soon as i get those made.
Soravia
Car: 2003 Audi A4 1.8T
I second Q45 and other possible Nissan/Infinity caliper/rotors. There are plenty of Nissan SUV out there that can donate parts to quickly stop a S chassis.
Soravia
Bump, you got any lead on Maxima rotors and calipers? Those look good too.
thang nguyen
Car: 1989 Nissan 240SX Fastback
I'm interested in a set for the R33 calipers and 350z track rotors.
tad_07
Car: 4x 95 240sx
I'd buy the z32 to 350z track
sil80drifter
any word yet on the hubcentric rings for the Cobra rotors? I really need them soon!
sil80drifter
Well, I got the hubcentric rings from http://www.ashspecz.com, and they are pretty much the same thing as you'd see for hubcentric rings for wheels that are too big for your hub, i.e. made from polycarbonate. It's said that the stuff doesn't melt and is better than metal... I guess we'll see although I remain scepticla on the materials ability to withstand the heat cycling of the brake rotors....On the other hand, LOOK! 17" wheels can fit the 13" rotors with a 10mm spacer (sorry no info on the wheels sock offset, forgot to look) --->
If the above doesn't work then here:
More info and pix later!sil80
seejaytoo
Car: 1993 240sx Hatch
i would be interested in some Z32 caliper/Z33 rotor brackes
sil80drifter
I don't think this thread went anywhere we haven't heard from the guy in ages...I hate it when ppl start one of those things, get everyones hopes up and then disappear.
sil80
sil80drifter
And here we go!!
You can call me "clearance daddy":
17" is nicely filled out by 13" of rotor:
Enjoy!
gumby74
I just recently replaced my brake pads (30mm Z32) and noticed the rotor had a minimum/replacement thickness of 28mm.If the Cobra rotor is in fact a 28mm rotor to begin with, wouldn't that be a bed starting place for a brake upgrade? Just curious.
sil80drifter
This is kind of comparing apples to oranges.
You are right, when it comes to 300ZX rotor. It is 30mm which when worn down to 28mm SHOULD be replaced, as the plates are now too thin for safety. The Cobra rotor is 28mm STOCK, i.e has a different minimal thickness (According to their FSM around 26.0096mm). Hence, don't worry they have plenty of thickness. Also, there is a reason why the Cobras will wear down slower than the 300ZX rotors - due to increased surface area that the 300zx pad is now dealing with. Should be a while before they wear down.
sil80
TubedSR86
Car: SR20DET powered AE86 with IRS
I would love a brake setup like this to fit 16" wheels... i cant run any larger. any ideas?
sil80drifter
yeh, run the VR-4 rotor upgrade, which fits under the stock 300ZX 16" wheel. There is no way the 13" Cobra rotor will ever fit under there. It's just too big, diameter wise.
sil80
Timtiminy
sorry about being gone for so long. I dont come on nico much. sil80drifter: How are you liking the setup?
