Q451990 »
https://forums.nicoclub.com/q451990-u142.html
Mon Jul 28, 2003 4:43 pm
LEDs have a lower current draw, so they have a lower load on the flasher. If there's a bad lamp, that also decreases current draw (as you mentioned).
I've read on a few sites that you need to switch to an electronic flasher vs. the other style. Which Q did you put LED signal lamps on? If it's the 92 the "combination flasher" is located under the steering column - check out the diagram on EL-151 - at least that's where it is in my 1991 manual.
Heath
