Turns over but wont start..
bigpinktits
Car: 240sx 1995 Ka-T
Hey Ya'll!
It's my daily driver so I need some help asap!!!
So my 95 240sx Ka-T turns over but will not start after working for 568miles. After an exhausting seach I have decided to make my own first post.
Quick senerio; Motor was fully rebuilt (from the ground up) using new stock parts and full Greddy Turbo kit, 568 miles ago. I live in Florida and we had a severe temp change. The car died 5 times in two days and the 3rd day would not start. Changed out the spark plugs to iridium, oil (mobile 1), oil filter(K&N), fuel filter, and distributor wireharness (old and brittle).
Checked the fuel rail and injectors (getting fuel). Checked for spark (getting spark). Checked compression (Good!).
Question; Could it be a crank sensor or the Emanage? Could the distributor have something wrong but allow spark (at the plugs or internal)? What else should I check???
bigpinktits
I ordered a new distriibutor today. I should have it in the next couple days. For some reason I think that's where the problem is... while testing, before new wire installed, when I jiggled it wanted to go but then never did so after. That's when I decided to change the distributor wire. zer...20990#Please if anyone has any idea's I am fresh out.
bigpinktits
bump.
Does anyone have any advice for me?
bigpinktits
So I just changed out the distributor and the car starts!!! Thanks for all the feed back! It runs like crap but at least it started...now onto adjusting the timing.
S-14boy
Car: 1998 Nissan 240SX SE
I hear you finally got it running. Is that true? ... Funny you were the only one the respond to your posts...
