turns but does not start, please help!!!!!!!!!!!!!!!!!!!!!!
kinkymike
Car: 93 240 sx se
hi guys, ive just compleated an engine swap on my 91 240sx, after replacing fuses and all the usual stuff turned the key and car started with no problems (first trun, first strart) just a lil idle problem due to a broken sensor i the intake manifold, replaced the sensor and corrected the problem, when i got my new tieres and wanted to take it out for a spin, the car did not want to start anymore.
checked fuel delivery... perfectchecked cables....... ohmms read wth in specschecked coil........... ohmms read with in specsvoltage to coil....... 12.30 volts
the problem is that there is no spark reaving the coil, i put a scre driver at the end of the coil calbe and put it clse to the engine block to see if theres a spark but theres nothing, took out the coil and took it to autozone (maybe i tested it wrong) but the guy said it was ok and that i didnt need a new one.....
im stuck can u guys please help me????????
im very anctious to take my car out for a first spin and posibly a first drift..so u might undestand my rustration...
thx for ur atention
ps sorry i forgot to specify that its a ka24de
neverlift
wiggle the cas wiring
jakes810
Car: 24O sx
First check if the battery is good and then ckeck the fuses then if its all good then it might be the coil pack it can also be the starter
jm
Car: 1990 nissan 240sx
if your engine spins when your trying to start it that means that your timing belt or chain is broken or worn.
s13drft89
Car: 1991 Twin Turbo 300zx & 1968 Mercury Cougar
jm wrote:if your engine spins when your trying to start it that means that your timing belt or chain is broken or worn.
How is your timing(disturbitor) marked on the correct spot
