Kendahl wrote:Normally, the rear view camera is part of the navigation package. Adding one to a car that doesn't have navigation is much more complicated than buying a camera from the parts department and plugging it into a blanked off hole in the trunk lid. For one thing, I doubt that Infiniti bothers to run wires to that location unless the navigation package has been ordered. Also, the computer program that controls the screen would have to be modified to recognize when you shift into reverse and switch to the camera view. The least expensive way to get the rear view camera is to buy a car with the navigation package even if you have no use for the navigation part. If it's too late for that, your only practical alternative is to trade for a car that does have it.
I felt the same as you about the navigation package. I have a laptop with a GPS receiver and map software from DeLorme. When the map database gets too old, I can buy the latest version for $40. However, the rear view camera is so neat that I wanted it badly enough to pay for the navigation I don't really need. The opposite was true for the adaptive headlights that are part of the technology package. I don't think they are all that valuable and I detest nanny crap like adaptive cruise control. Therefore, I passed on the technology package.
I have to disagree with you. The tech package for me here is 3000+ and seriously I can wire up everything like stock for 500. How? Ok, here are some options:
Get an after market camera and mount it in the hole where the stock camera is supposed to be, I have not looked at one w/o the camera to see how it is different etc or what parts are available.. I will call in a bit and post back... but either way, use stock location or find another, link the power to the camera to the reverse lights, so they power on when the lights do, or if you need more power just use the reverse lights as a trigger and power the camera from elsewhere, but I think it should be sufficient.
So that done your camera turns on whenever your reverse lights do which is whenever you put the car into reverse. Now next step, you router the wires under the carpet along the doors maybe and to your dash (small issue if you are patient and somewhat savy) and you hook it up to your aux or whatever.. there are many solutions for that.. small issue.. theres already stock RCAs for the AUX in the centre arm rest, so to hook up a camera to AUX would be the easiest, but I am sure there could be another way... so if you do that whenever you reverse, just press aux.. and you would have the cam display up... TADA... end of story......
the only diff with the stock cam is that it uses some software to guide you... which I think is un-neccessary so if I can get the physical camera as a replacement part, I am pretty sure it could be rigged up to AUX sooooo easy.... not kidding you.. question now is.. hows the back like for those w/o the nav/camera and the cost of parts.
