turning turbo center section?
lilskyline240
Car: 90 240sx w/ rb30det
Ok i got a pulsar GTir turbo and i cant seem to turn the damn center section to get the oil feed line to point up. i loosen all the bolts connecting it to the exhaust housing and it still wont turn. is there a special trick to doing it?
Seishuku
Car: 1987 Nissan S12, 5-speed, SR20DE+T 50trim T3@15PSI, Megasquirt 1 029y4
A very large rubber hammer.
Seriously.
It's probably just rusted, so you'll have to break it free.
lilskyline240
hit on what? the compressor housing?
Seishuku
Pretty much. What I did, is I clamped the turbine (exhaust) inlet flange in a bench vise, then gave the compressor a good whack.
I would soak it with some RD90/WD40/PB Blaster/whatever overnight first, then go to work on it.
Just be VERY careful when it does come loose, as to not damage the turbine blades.
lilskyline240
finally got it. BFH, a rubber one...works wonders
