Turning rotors with new pads?
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
gwoods
Car: 2013 Infiniti M37x
1999 Nissan Altima SE limited 5spd
1992 Miata (soon to be turbo)
1965 Cj-5 with 327 v8
2012 Toyota Sequoia Limited
SO, in Feb I put on drilled/slotted rotors and ceramic/kelvar pads
Today I had the rear tires off and inspected the brakes, the pads probably have somewhere between 30-40% pad left so I'm looking at replacing them in the next 3-4 months.
Do I HAVE to turn the rotors if they are not damaged and the pads are the the same brand ect ect??
The reason I am apprehensive about turning the rotors is they are drilled and I think I may have some cracking if I turn them??
New brakes back in feb,
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
It's not necessary unless there are imperfections in the rotors. I don't think its recommended to turn them anyways.
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
I've done this with other vehicles before. As long as the rotors aren't warped I've never had any trouble. Just make sure they are clean.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
